It is currently Sun Jun 22, 2025 7:35 pm
 Post subject: Weird revving issue
PostPosted: Wed Jan 24, 2024 1:11 pm
OK, this is gonna sound dumb but here goes.
With our Mk.1 970 Cooper S the engine increases in revs when you pull up to a stop and have your foot on the brake pedal.
I have looked at the accelerator cable and cannot see any interference at all from the pedal to the carbies.
There has gotta be something simple I am missing; can anyone help me out?
 Post subject: Re: Weird revving issue
PostPosted: Wed Jan 24, 2024 1:27 pm
Running a brake booster? If so, check the rubber diaphragm. Had similar issue years ago, brake booster diaphragm had small crack. To test disconnect and block booster hose from manifold at the booster end. If still an issue, it's not the diaphragm.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed Jan 24, 2024 4:26 pm
Brake booster also has a one way valve where the hose enters the booster body.
Cheers Dave.
PostPosted: Wed Jan 24, 2024 5:54 pm
ditto to the booster diaphragm - you can take the hose off the inlet manifold and suck on it - if the air keeps on coming then there's a crack
