https://ausmini.com/forums/
Wheel bearings
https://ausmini.com/forums/viewtopic.php?f=2&t=102106
Author:  Goldbrocade_62 [ Sat Dec 23, 2023 6:38 pm ]
Post subject:  Wheel bearings
What front tapered roller bearings best to use timken or generic I do realise the will need setting up just seeing what doesn't flog out 2 weeks later
Author:  68+86auto [ Sat Dec 23, 2023 8:59 pm ]
Post subject:  Re: Wheel bearings
Timken for sure.
Author:  drmini in aust [ Sun Dec 24, 2023 7:03 am ]
Timkens they're worth it.
Too much messing about with the cheap ones to get preload correct.
Author:  cooperess [ Sun Dec 24, 2023 7:09 am ]
What is the Timken bearing part number?
Author:  cgo [ Sun Dec 24, 2023 12:51 pm ]
Checked an old Network bearing kit I have in the shed.
LM67014 is the outer,
LM67049A is the inner,
LM67049XA is the spacer,
Kit included 2 oil seals.
Author:  DavidE [ Sun Dec 24, 2023 2:45 pm ]
The current popular identity for the front wheel bearing kits is GHK1140. Not all suppliers are including Timken bearings. Make sure you read the fine print, or make a phone call before buying. Anything around $50 a set is not what you want.
Author:  Goldbrocade_62 [ Sun Dec 24, 2023 6:36 pm ]
I will chase up some timken bearing much appreciated
