It is currently Mon Jun 23, 2025 6:53 am
 Post subject: Wheel bearings
PostPosted: Sat Dec 23, 2023 6:38 pm
What front tapered roller bearings best to use timken or generic I do realise the will need setting up just seeing what doesn't flog out 2 weeks later
 Post subject: Re: Wheel bearings
PostPosted: Sat Dec 23, 2023 8:59 pm
Timken for sure.
Too many minis
PostPosted: Sun Dec 24, 2023 7:03 am
Timkens they're worth it.
Too much messing about with the cheap ones to get preload correct.
PostPosted: Sun Dec 24, 2023 7:09 am
What is the Timken bearing part number?
PostPosted: Sun Dec 24, 2023 12:51 pm
Checked an old Network bearing kit I have in the shed.
LM67014 is the outer,
LM67049A is the inner,
LM67049XA is the spacer,
Kit included 2 oil seals.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sun Dec 24, 2023 2:45 pm
The current popular identity for the front wheel bearing kits is GHK1140. Not all suppliers are including Timken bearings. Make sure you read the fine print, or make a phone call before buying. Anything around $50 a set is not what you want.
PostPosted: Sun Dec 24, 2023 6:36 pm
I will chase up some timken bearing much appreciated
Users browsing this forum: No registered users and 119 guests
