https://ausmini.com/forums/
Installing windscreens
https://ausmini.com/forums/viewtopic.php?f=2&t=102070
Author:  Bill B [ Thu Nov 16, 2023 5:09 pm ]
Post subject:  Installing windscreens
I have just finished fitting the rear windscreen.
It isn't a job to look forward to but I found a useful item that seemed to make the job a lot easier. Maybe everyone else knows about this, or has a better idea, but I'm posting this so it might help.
I normally use blunt screwdrivers or paint scrapers but they can, and did, nick the rubber seal.
The tool sold to insert the filler strip does a good job at this - the round section wire is less likely to nick the rubber seal. I also used rubber grease on the seal as the usual detergent solution dries out so quickly.
Author:  Steam [ Thu Nov 16, 2023 6:33 pm ]
Post subject:  Re: Installing windscreens
I found that the tool you show bent too easily to be of any use.
But yes to the rubber grease and I use a piece of plastic tongue from flooring boards and file the correct profile I need.
Author:  cruiser23 [ Thu Nov 16, 2023 7:11 pm ]
Check out this thread. I tried it and it works a treat.
http://www.ausmini.com/forums/viewtopic.php?f=2&t=96127
Author:  68+86auto [ Thu Nov 16, 2023 8:39 pm ]
I used body filler applicators (plastic ones). I wonder if tyre fitting paste would be a good solution instead of dishwashing liquid.
