https://ausmini.com/forums/
Retorque head - hot or cold?
https://ausmini.com/forums/viewtopic.php?f=2&t=102000
Author:  Bill B [ Thu Aug 31, 2023 3:21 pm ]
Post subject:  Retorque head - hot or cold?
When re torquing the cylinder head, is it done hot or cold?
Replaced a previous 1275cc gasket due to an oil leak between the head and block.
I have fitted a copper/steel gasket with Hylomar sealant and have taken the car for a few short runs to the shops etc. All seems good and the leak has stopped.
When I recheck the torque on the head, is it meant to be cold or hot?
Author:  gtogreen1969 [ Thu Aug 31, 2023 3:37 pm ]
Post subject:  Re: Retorque head - hot or cold?
Cold
Author:  68+86auto [ Thu Aug 31, 2023 3:38 pm ]
Cold
Author:  gtogreen1969 [ Thu Aug 31, 2023 3:46 pm ]
Not sure if it really matters that much on a mini engine because i have seen people do it both ways without any issues. As long as you retorque them because they can loosen 5-10 ft/lb after an initial run in depending on the gasket used. The copper steel gasket wont squash down as much as a cheep composite gasket. The theory behind hot retorquing is that the steel studs expand a bit more than the cast head.
Author:  GR [ Thu Aug 31, 2023 6:25 pm ]
HI All
When you torque a head down for cast iron heads you do it when hot
For alloy heads do them when they are cold.
Graham Russell
Author:  lomin [ Thu Aug 31, 2023 8:53 pm ]
100% for GRR
And when retorqueing , back of each bolt as you do it half a turn,then come forward and then you wont only read the break away torque.
I also suggest loosening / removing radiator cap to remove coolant pressure whilst you are doing this job.
cheers Lindsay
Author:  eightfifty [ Thu Aug 31, 2023 9:27 pm ]
I looked up the drawings for the hot run test and in all cases, A B and E series engines, the cylinder head nuts are retorqued with the engine at normal operating temperature. For P76 V8, no retorque specified.
Author:  68+86auto [ Sun Sep 03, 2023 10:46 am ]
When does everyone do the retorque? Km/time etc
Author:  Bill B [ Sun Sep 03, 2023 11:21 am ]
....and would there be any difference between a newly rebuilt engine and just a head gasket replacement on a motor already run-in?
Thanks for the replies and for the little technical tips. Always worth hearing.
Author:  drmini in aust [ Sun Sep 03, 2023 12:08 pm ]
No difference new build or gasket replacement. Run until hot, retorque, adjust valves.
Recheck after 500km or so. When hot.
Author:  Steam [ Sun Sep 03, 2023 5:51 pm ]
Do you need to retorque the head having used one of the various lifting brackets that use the head studs and if so do you do the whole thing or just those that were disturbed?
Author:  FNQ [ Mon Sep 04, 2023 6:42 am ]
Good question Dave...... I don't have an answer but thought i would add unrequested info anyway ( sorry forum)
I don't like the brackets that use the cylinder head studs ...unless of course you are going to take the head off anyway....because of some possible impact on the gasket seal...probably unfounded fear
and for another 2 cent worth , tappet lash measured hot as well.
Author:  drmini in aust [ Mon Sep 04, 2023 7:19 am ]
I just retorque the bracket studs.
A series head is stiff, it's Detroit wonder metal, not soft rubbish alloy like modern cars.
