https://ausmini.com/forums/
Easier out radiator removal?
https://ausmini.com/forums/viewtopic.php?f=2&t=101997
Author:  Barkfast [ Mon Aug 28, 2023 1:06 pm ]
Post subject:  Easier out radiator removal?
I'd like to take out my radiator, and had a question on Matt Read's suggested guide below.
The guide suggests removing both bolts circled in red, but looking at it.. is there any reason why I couldn't instead remove the 2 bolts circled in yellow? These seem much easier to access....
Firstly, you take the 2 engine mount bolts & nuts out from the passengers side,,, then jack the engine up on that side,
2ndly you undo & remove the 2 vertical bolts that mount the bottom radiator bracket to the engine mount bracket (Not the 2 bolts that are located side ways through the lower radiator bracket to the lower radiator cowl, just leave them there),
then with the top radiator bracket & both top & bottom radiator hoses un-clamped, it’s just a matter of lifting the whole assembly, radiator with cowls attached , in one big bit, straight up & out of the hole... easy-peasy
Author:  Steam [ Mon Aug 28, 2023 5:14 pm ]
Post subject:  Re: Easier out radiator removal?
The bracket would still be held in place with the engine mount. Also the long bolts are a pain to get out anyway.
The red ones give easy removal but refitting can be pain to line them both up again. Just persevere.
Author:  timmy201 [ Mon Aug 28, 2023 5:32 pm ]
The red ones aren’t too bad with a ratcheting spanner, just undo the front one first
The yellow ones aren’t too bad either (as Matt’s method involves removing the LH engine mount already) I believe it’s just harder to remove the rad with that lower bracket attached
Author:  Barkfast [ Mon Aug 28, 2023 5:38 pm ]
Thanks for the replies Dave and Timmy.. I'll give it a crack.
Author:  fffffred [ Mon Aug 28, 2023 9:49 pm ]
I ended up grinding the harder to get to bolt so it became a locating pin...
