It is currently Mon Jun 23, 2025 8:11 am
PostPosted: Mon Aug 28, 2023 1:06 pm
I'd like to take out my radiator, and had a question on Matt Read's suggested guide below.
The guide suggests removing both bolts circled in red, but looking at it.. is there any reason why I couldn't instead remove the 2 bolts circled in yellow? These seem much easier to access....
Firstly, you take the 2 engine mount bolts & nuts out from the passengers side,,, then jack the engine up on that side,
2ndly you undo & remove the 2 vertical bolts that mount the bottom radiator bracket to the engine mount bracket (Not the 2 bolts that are located side ways through the lower radiator bracket to the lower radiator cowl, just leave them there),
then with the top radiator bracket & both top & bottom radiator hoses un-clamped, it’s just a matter of lifting the whole assembly, radiator with cowls attached , in one big bit, straight up & out of the hole... easy-peasy
PostPosted: Mon Aug 28, 2023 5:14 pm
The bracket would still be held in place with the engine mount. Also the long bolts are a pain to get out anyway.
The red ones give easy removal but refitting can be pain to line them both up again. Just persevere.
Cheers Dave.
PostPosted: Mon Aug 28, 2023 5:32 pm
The red ones aren’t too bad with a ratcheting spanner, just undo the front one first
The yellow ones aren’t too bad either (as Matt’s method involves removing the LH engine mount already) I believe it’s just harder to remove the rad with that lower bracket attached
PostPosted: Mon Aug 28, 2023 5:38 pm
Thanks for the replies Dave and Timmy.. I'll give it a crack.
PostPosted: Mon Aug 28, 2023 9:49 pm
I ended up grinding the harder to get to bolt so it became a locating pin...
