https://ausmini.com/forums/
Lucas 23D & 25D Distributor Question
https://ausmini.com/forums/viewtopic.php?f=2&t=101956
Author:  cooperess [ Thu Jul 27, 2023 12:52 pm ]
Post subject:  Lucas 23D & 25D Distributor Question
Are the rotors, top entry caps and points all the same part numbers?
If not please advise the part numbers for each type of distributor.
I have tried g o o g l e and have been very confused.
25D
rotor =
top entry cap =
points =
23D
rotor =
top entry cap =
points =
Author:  timmy201 [ Thu Jul 27, 2023 1:18 pm ]
Post subject:  Re: Lucas 23D & 25D Distributor Question
Yes, 23D and 25D are dimensionally the same.
23D has no vacuum advance
25D has vacuum advance
There are a few different cap types (side entry, top entry) and different rotors but are interchangeable
There are standard points and heavier weight points
Author:  DavidE [ Thu Jul 27, 2023 2:05 pm ]
25D
rotor =
top entry cap =
points =
23D
rotor =
top entry cap =
points =
The part numbers of each depend upon the application that each was originally fitted to. I do have a table somewhere, ........
Author:  68+86auto [ Thu Jul 27, 2023 4:23 pm ]
As already mentioned there may be different "pair" of parts depending on the application but basically each "pair" can be moved between a 23D and 25D.
The rotor for example might be different depending on the cap type, at least it is on some of the later distributors.
I wish my Bosch ignition parts catalogues would list the distributor model but they don't so I can't check part numbers easily.
Author:  cooperess [ Thu Jul 27, 2023 4:33 pm ]
Not sure what is meant by 'pair' but I would like to use them on a Mini.
Author:  timmy201 [ Thu Jul 27, 2023 4:48 pm ]
One example for you: a mini distributor spins anticlockwise, so the rotor (in this case GL229) has an arrow and an extended leading edge. Others are straight, and others have an extended tip on the other side to suit a clockwise distributor
As long as you buy parts from a mini specific shop they should work fine
Author:  68+86auto [ Thu Jul 27, 2023 5:42 pm ]
What I meant by pair is rotor and cap.
I know at least the later distributors used a different rotor depending on side or top entry cap.
Author:  cooperess [ Thu Jul 27, 2023 5:47 pm ]
I've been to that site 'timmy' and bought different parts recently, if you look at all the pictures there are 2 different rotors so I don't know what I will get.
Author:  68+86auto [ Thu Jul 27, 2023 6:07 pm ]
Because of that I would order from elsewhere, maybe you could contact them to find out what type you will get. Not sure whether the older style would've been fitted originally to 25/23ds or not but they are what I have seen on DKY and DM2 distributors. I will look later and see if Bosch specified them as the same.
Author:  68+86auto [ Thu Jul 27, 2023 8:29 pm ]
Both appear to be interchangeable as classic motoring indicates, I didn't know DM2 and DKY distributors used the same rotor as a 25/23d. The different designs must just be because they updated the design. I wonder when the "new" design was introduced, would minis have had the old one at all.
Author:  timmy201 [ Fri Jul 28, 2023 7:26 am ]
The DM2 was used on early 850’s according to my parts manual
The DM2 Lucas service parts list is below, for example the rotor is part number 400051 which is interchangeable with 25D
