https://ausmini.com/forums/
Gear Selector Forks
https://ausmini.com/forums/viewtopic.php?f=2&t=101898
Author:  cooperess [ Fri Jun 16, 2023 12:32 pm ]
Post subject:  Gear Selector Forks
These nuts are hard to screw and unscrew. Please give me your ideas.
Author:  drmini in aust [ Fri Jun 16, 2023 2:55 pm ]
Post subject:  Re: Gear Selector Forks
I use a ring spanner. Get to the 1-2 fork nut through the diff opening.
Author:  Phil 850 [ Fri Jun 16, 2023 8:17 pm ]
“These nuts are hard to screw and unscrew” as in the access to them or they are physically tight on the thread.
If they are physically tight, pull them all apart and run die nuts/taps over them.
The bolt may be difficult to remove as the end may have burred over where they tighten against the shaft. WD40 and brute force may be required to remove them.
Phil
Author:  IndigoBlueCooperS [ Sat Jun 17, 2023 8:49 am ]
As the Dr said, you need the correct ring spanners for these - Just standard quality tools.
If one did become damaged it would be due to poor workmanship. I would toss it out and use a good second hand one. No trying to clean up the thread for me.
Not something I would want to come loose for obvious reasons. I put a drop of Locktite on them.
Author:  Bill B [ Sat Jun 17, 2023 11:45 am ]
I use a small ring spanner 1/8W for the screw. An old set of these screws I have are marked WILEY (maker) and "T" (grade) so meant to take a high tension. Even the locknuts have a grove in them for identification.
Author:  drmini in aust [ Sat Jun 17, 2023 2:01 pm ]
It's not fun if one comes loose. After all that work, rinse and repeat. :roll:
Been there, done that. Once......
