https://ausmini.com/forums/
Fuel and temp gauge
https://ausmini.com/forums/viewtopic.php?f=2&t=101878
Author:  carter [ Sat Jun 03, 2023 4:11 pm ]
Post subject:  Fuel and temp gauge
My temp and fiel gauge work but after another 2 minutes they just stop...
Have checked earth new stabiliser any ideas what it xould be ?
Author:  gtogreen1969 [ Sat Jun 03, 2023 4:27 pm ]
Post subject:  Re: Fuel and temp gauge
When the gauges stop -
1. Is the stabilizer still putting out 10v on the I terminal? Sounds like the contacts are staying open and not resetting.
2. Does the B terminal have 12v? If not then there might be a high resistance connection on the fused power.
Author:  carter [ Sat Jun 03, 2023 6:29 pm ]
12 volt one end the other 2 have 5. Something almost 6 v
Author:  DavidE [ Sat Jun 03, 2023 6:38 pm ]
Two minutes after what?When you say they stop, are you saying they go to empty and cold?
Is the engine running? Is the fan belt not correctly tensioned?
Author:  drmini in aust [ Sat Jun 03, 2023 6:39 pm ]
It's a dud.
Get an electronic one. PM wombat on here or PM me for his mobile #
Author:  carter [ Sat Jun 03, 2023 6:50 pm ]
Engi n e running guages go back to E and C
Author:  gtogreen1969 [ Sat Jun 03, 2023 7:22 pm ]
With a battery voltage to the B terminal and a good earth to the stabilizer body and less than 10 volts at the I terminal means the internal contacts are remaining open longer than they should or they have dirty contacts.
You could try to open the box and clean the contacts points first.
To raise the 6V to 10V you might need to apply more pressure to the bimetallic strip by bending it a bit.
The best option is to convert to electronic.
A bit of info here - https://www.minimania.com/Smiths_Voltage_Stabilizers
Author:  TK [ Sat Jun 03, 2023 7:38 pm ]
GTO a great link. Thank you
Author:  carter [ Sat Jun 03, 2023 9:27 pm ]
its brand new so i may give the people a call who i bought it off.
