3D Print https://ausmini.com/forums/viewtopic.php?f=2&t=101756 |
Author: | rodaz [ Wed Mar 15, 2023 7:10 pm ] |
Post subject: | 3D Print |
I needed a neat solution to mount my tachometer. A quick design in Fusion 360 and off to the resin printer. It could be used for any 50mm gauge. Left or right side of the cluster. |
Author: | braad [ Wed Mar 15, 2023 8:16 pm ] |
Post subject: | Re: 3D Print |
Very nice! I really like how people are utilising 3D printing to make or recreate parts |
Author: | jaybee [ Wed Mar 15, 2023 8:27 pm ] |
![]() Nice work |
Author: | surtees [ Thu Mar 16, 2023 7:11 am ] |
Nice work, very neat solution. |
Author: | Gambo [ Thu Mar 16, 2023 7:44 am ] |
Fantastic work, any chance you could share the file for others to print? |
Author: | cooperess [ Thu Mar 16, 2023 10:11 am ] |
I need a tacho, does it work well and what is the part number? |
Author: | rodaz [ Thu Mar 16, 2023 7:20 pm ] |
Gambo wrote: Fantastic work, any chance you could share the file for others to print? I have put it up on Thingaverse. https://www.thingiverse.com/thing:5913417 |
Author: | rodaz [ Thu Mar 16, 2023 7:26 pm ] |
cooperess wrote: I need a tacho, does it work well and what is the part number? The tacho works ok, as does the temp and oil gauges. I chose this brand because the temp and oil gauges are electronic. Search for "Tachometer gauge 8000 RPM Speco Street 52mm 2" black 523-20" |
Author: | cooperess [ Thu Mar 16, 2023 8:14 pm ] |
rodaz wrote: cooperess wrote: I need a tacho, does it work well and what is the part number? The tacho works ok, as does the temp and oil gauges. I chose this brand because the temp and oil gauges are electronic. Search for "Tachometer gauge 8000 RPM Speco Street 52mm 2" black 523-20" |
Author: | Gambo [ Fri Mar 17, 2023 7:48 am ] |
rodaz wrote: Gambo wrote: Fantastic work, any chance you could share the file for others to print? I have put it up on Thingaverse. https://www.thingiverse.com/thing:5913417 Champion - thanks! |
Author: | Gambo [ Mon Aug 28, 2023 2:54 pm ] |
Had a friend print this for me last week, came out absolutely top notch. Thanks again! |
Author: | Steam [ Mon Aug 28, 2023 5:19 pm ] |
Nice pod. A Speco 52mm tacho I have, the needle bounces around, not sure of the model though. |
Author: | drmini in aust [ Tue Aug 29, 2023 9:44 am ] |
That looks neat I agree. I needed a bigger tachometer so got an Autogage one. Made by autometer. https://www.ebay.com.au/itm/164408368664 The body rotates 360° so you just screw it to the shroud. I've had mine for years it's accurate and well damped. Edit And it's half the price of a Smiths. |
Author: | GuamMini [ Mon Aug 12, 2024 10:02 am ] |
Nice |
