It is currently Wed Jun 25, 2025 11:23 am
PostPosted: Sat Feb 25, 2023 6:15 pm
I am puting the heater duct back into a 1972 Clubman - The under gaurd bit.
Is there a steel spacer between the front plastic bit and the flexible duct - ref first photo.
A similar spacer to that attached to the 90 degree bend in the second photo.
PostPosted: Sat Feb 25, 2023 6:49 pm
Online
HI IndigoBlue CooperS
Yes there is a steel sleeve each end of the flex tube
Can I ask where you got the flex tube from ?
I also need to fit the ducting to my van
Thanks
Slacko
PostPosted: Sat Feb 25, 2023 8:17 pm
Slacko
Thanks Slacko,
Flex tube came from Minisport SA.
So far it looks the goods.
Any idea where I might find the missing steel tube?
PostPosted: Sat Feb 25, 2023 8:33 pm
Thanks
Slacko
It looks to be made from thick aluminium foil - no cardboard or paper involved.
Good fit on the sleeve, and a good length once extended.
PostPosted: Sat Feb 25, 2023 9:48 pm
Online
Try minisport SA
I think they may have them
PS
Just ordered all the ducts for my car
slacko
PostPosted: Mon Feb 27, 2023 1:35 pm
I bought flex tube like that from bunnings for a clubman I did some work on (which I now own)
Users browsing this forum: drmini in aust, slacko and 84 guests
