It is currently Sat Jun 28, 2025 12:34 pm
PostPosted: Sun Feb 12, 2023 6:02 pm
I replaced the suspension bushing and pin on the lower suspension arm to subframe and ever since my suspension sit so high I thought it would eventually settle but it does not. What could I have done wrong?
1973 Clubman GT - YG2S8 1637
PostPosted: Sun Feb 12, 2023 6:54 pm
Has the knuckle joint or trumpet come out of position? Otherwise it shouldn't change the height.
Too many minis
PostPosted: Sun Feb 12, 2023 7:30 pm
If it's hydro (a GT?) It's important to check the knuckle pin is into the hydro bag piston before pumping up. If the piston is an alloy one they crack easy if you don't.
PostPosted: Mon Feb 13, 2023 8:20 am
Thank you I will check on this sometime this week
Users browsing this forum: Bing [Bot] and 85 guests
