It is currently Fri Jun 27, 2025 12:47 am
PostPosted: Wed Feb 01, 2023 11:28 am
Hi All,
I've done a bit of a search and found lots of info for tank breathers if running two tanks i.e crossing them over.
For a single tank do you still run it across the parcel shelf and exit through the floor near battery box?
Thank you
PostPosted: Wed Feb 01, 2023 11:32 am
A single tank just goes straight down on the same side
The twin tanks cross over as if you park on a steep side angle, the fuel can transfer from one tank to the other via the link pipe, and you need the breather to be higher than the fuel level
PostPosted: Wed Feb 01, 2023 11:33 am
Ok thanks mate.
