https://ausmini.com/forums/
Fuel tank breather single tank
https://ausmini.com/forums/viewtopic.php?f=2&t=101691
Author:  surtees [ Wed Feb 01, 2023 11:28 am ]
Post subject:  Fuel tank breather single tank
Hi All,
I've done a bit of a search and found lots of info for tank breathers if running two tanks i.e crossing them over.
For a single tank do you still run it across the parcel shelf and exit through the floor near battery box?
Thank you
Author:  timmy201 [ Wed Feb 01, 2023 11:32 am ]
Post subject:  Re: Fuel tank breather single tank
A single tank just goes straight down on the same side
The twin tanks cross over as if you park on a steep side angle, the fuel can transfer from one tank to the other via the link pipe, and you need the breather to be higher than the fuel level
Author:  surtees [ Wed Feb 01, 2023 11:33 am ]
Ok thanks mate.
