https://ausmini.com/forums/
Dumb question... bolt too big on tie rod?
https://ausmini.com/forums/viewtopic.php?f=2&t=101660
Author:  Barkfast [ Sat Jan 07, 2023 9:52 pm ]
Post subject:  Dumb question... bolt too big on tie rod?
Ok.. so dumb question..
I went to try replacing the tie rod rubbers today.. but when I tried to remove the bolt from the tie rod (at the hub end)... it seems too big to be removed. When I try to lift it, it just fowls the CV boot. By the time the bolt hits the CV boot - I would estimate there's around 5 mm left.
Is there any trick to getting it out?
Author:  timmy201 [ Sat Jan 07, 2023 9:55 pm ]
Post subject:  Re: Dumb question... bolt too big on tie rod?
It should only need to be long enough to get a nut on the end. If you really get stuck you could pop off the ball joint to give more room
Author:  Nev [ Sun Jan 08, 2023 7:00 am ]
Try jacking the hub up, it should open up the gap enough to wiggle the bolt out.
