It is currently Wed Jun 25, 2025 9:51 pm
 Post subject: Indicator problem
PostPosted: Tue Apr 20, 2021 1:56 pm
Just discovered that the passenger side indicators are working on my Mk 2 S, but the driver's side aren't. What is the likely problem/solution?
1970 Cooper S SPO41
 Post subject: Re: Indicator problem
PostPosted: Tue Apr 20, 2021 2:05 pm
If it's both front and rear then I would be looking for a bad connection on the indicator stalk bullet connector plug.
PostPosted: Tue Apr 20, 2021 2:26 pm
Thanks. Where will I find the connector bullet you refer to? Have been fiddling around at the back of the speedo. Any chance I could have dislodged a relevant wire there?
Sent from my SM-A305YN using Tapatalk
1970 Cooper S SPO41
PostPosted: Tue Apr 20, 2021 2:33 pm
Next to the steering column. Just follow the wiring loom coming out of the indicator stalk. The old bullet connectors probably have a high resistance connection due to corrosion.
PostPosted: Tue Apr 20, 2021 5:21 pm
Thanks again, think it's the green/white wire I should be looking for? If there is a bad earth at the dashboard indicator light would that also cause both the driver's side indicators to fail to operate?
On a separate, but related note, both gauges (water temp, oil pressure) fail to light when lights are switched on. No problem with the lights in the speedo and fuel gauge. Have replaced the bulbs, but still no joy. Any ideas?
1970 Cooper S SPO41
PostPosted: Tue Apr 20, 2021 5:40 pm
Check gauge bodies are well grounded to the speedo housing.
PostPosted: Tue Apr 20, 2021 5:46 pm
Yes Green/White should be drivers side indicators
The dash indiator globes are inline and are not earthed themselves. The reason the dash indicator globe is not lighting up is because there is either no power to the circuit or no circuit to earth.
Might be time to have a look at the wiring diagram, trace the wires and break out the multimeter.
PostPosted: Fri Apr 23, 2021 2:17 pm
Update on the indicator problem. Changed the bullet connection, still no joy. However the rear driver's side indicator does glow (very dull), but not flash, as does the panel light (also very dull). The driver's side front doesn't do anything. Interestingly, when the passenger side indicator is activated, everything works well for that side. Except that very occasionally instead of the passenger side panel light flashing, the driver's side glows (not flashes) briefly before switching back to the correct side. Any ideas/solutions?
1970 Cooper S SPO41
PostPosted: Fri Apr 23, 2021 2:40 pm
Install a temporary earth to your rh side rear light cluster and see if things improve.
PostPosted: Fri Apr 23, 2021 6:05 pm
Have a read of my post dated Nov04 2020 (Indicator Issues). I just had a quick read of my post and there are similarities.
My problem ended up being a broken connection on the positive feed to the flasher.
PostPosted: Fri Apr 23, 2021 8:13 pm
Thanks Fritzie, will take a look
1970 Cooper S SPO41
PostPosted: Mon Apr 26, 2021 4:23 pm
Update on the indicator problem, now resolved. Issue was a burnt front indicator globe. Moral of the story being for me to look for the obvious next time rather than assume something more sinister
1970 Cooper S SPO41
PostPosted: Sun Jan 22, 2023 10:31 am
Yesterday I was assisting in fitting a new loom into an 850. All went well until we were almost finished when testing the indicators which were working fine. With the indicators working we then turned on the lights resulting with the RHS parking light going brighter and the indicator going very dim. LHS ok. Any thoughts. Thanks Jim.
PostPosted: Sun Jan 22, 2023 11:18 am
Install a temporary earth from the light fixture at the RHS rear. Run it from the fixture to the battery earth and check for results.
