https://ausmini.com/forums/
Boot Board Brackets.
https://ausmini.com/forums/viewtopic.php?f=2&t=101627
Author:  gtr161 [ Sat Dec 17, 2022 8:47 am ]
Post subject:  Boot Board Brackets.
Can someone help me out with the location of the 3 boot board brackets found onthe cooper s - so RH tank model. I'm pretty sure the middle bracket with the rubber insert is located centrally in the aperture but just need the offsets to the other two. Cheers,
Author:  cgo [ Sat Dec 17, 2022 3:34 pm ]
Post subject:  Re: Boot Board Brackets.
See photo, can provide measurements, if you wish. Not a symmetrical arrangement.
Author:  gtr161 [ Sat Dec 17, 2022 6:12 pm ]
Awesome, thanks CGO, I do like a good measurement.. if you wouldn’t mind. It appears that the offside one lines up with the middle of the boot hinge, and the near side one is on the inner edge of the boot hinge.. (I don’t have a boot board at the moment, or a RH fuel tank)
Author:  ausdino [ Sat Dec 17, 2022 7:01 pm ]
I hope these are of some use, shell is on rotisserie at the moment and upside down.
* Rhs rivet is 15mm to left of Rhs boot hinge centre between bolt holes
* Middle mount is 215mm to left of Rhs rivet or 230mm left of Rhs boot hinge centre between bolt holes
* Lhs rivet is 53mm to left of Lhs boot hinge centre between bolt holes
Author:  gtr161 [ Sat Dec 17, 2022 7:21 pm ]
Perfect! Awesome, problem solved.. thanks all, much appreciated.
