It is currently Thu Jun 26, 2025 2:30 pm
PostPosted: Tue Dec 06, 2022 4:15 pm
I need help reassembling my non-verto clutch. I understand that the flywheel, pressure plate, and clutch cover have an embossed identifier (sometimes an “A”) that must be lined up with one another for balance. I marked each one with a sharpie during disassembly just in case the factory marks were illegible. When it came time to button everything up, I realized I had wiped off my sharpie marks, and of course, except for the clutch cover, the factory marks were illegible.
I had my flywheel and pressure plate lightened and balanced when my engine was assembled and there are balancing holes drilled in both. I thought if I aligned the balancing holes with one another the flywheel/pressure plate assembly would be in balance. Does this make sense? Unfortunately, when I fastened them together, the closest I could get the balancing holes to align is about 30° off, given the bolt pattern of the flywheel & pressure plate. And I don’t know how the “A” on the clutch cover relates to any of this. Any ideas would be appreciated. I’ve cross-posted this in a couple of forums, so please forgive the redundancy.
Michael, Santa Barbara, CA
. . . the sled, not the flower
https://www.facebook.com/PoserMotorSports/
PostPosted: Tue Dec 06, 2022 4:18 pm
I would say that they both have been balanced independently of each other, Hence the holes in different areas
PostPosted: Tue Dec 06, 2022 5:28 pm
I don’t suppose you took any photos of the pair prior to cleaning?
PostPosted: Tue Dec 06, 2022 6:49 pm
Hi, most times when a balancing person balances an engine they put their own marks on the assembly. maybe little punch marks near one bolt hole...See how lucky you may be. cheers Lindsay
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Wed Dec 07, 2022 6:33 am
If no mark dots or paint spots I would put it on a crankshaft and get its balance checked.
When I did them I do the flywheel first, then bolt the backplate on and do it, then fit the diaphragm and use best of its 3 positions. Sometimes need to drill a hole it that or add a spot of weld.
Then paint mark all 3 components.
