It is currently Thu Jun 26, 2025 9:30 am
PostPosted: Wed Oct 26, 2022 11:18 am
Wanting to know how I can remove the gear lever (remote change) on my '69 K.
I was looking to replace the aftermarket knob and gator.. but ran into trouble as the previous owner decided to glue (maybe epoxy) the after market knob. I've since stripped the grub screw heads and started to drill out the screws ... but I'm thinking it would be safer to remove it from the car and work on it on a bench.
... so is it just a matter of undoing the 2 large screws and retainer plate and lifting up?
PostPosted: Wed Oct 26, 2022 12:08 pm
I haven't done it myself but looks that way, I'd say take car with the spring and seat.
PostPosted: Wed Oct 26, 2022 1:04 pm
Yep, just undo the 2 big screws
It’d be worth checking the nylon bush on the bottom of the shifter is still nice and tight. Also make sure the “primary shaft lever” in the picture above is nice and tight on the “primary shaft” and doesn’t slide about.
PostPosted: Wed Oct 26, 2022 5:57 pm
Sometimes the “split bush” grips the side of the bottom ball of the lever so may need a decent tug to get it free. Other version of the bush are just a cup and the lever will just lift up.
Have you checked that there’s not a locking nut (that needs to be undone) under the knob?
Cheers, Ian
PostPosted: Fri Oct 28, 2022 9:49 am
Thanks for everyone's help.
There doesnt appear to be a locking nut. On the current knob, the only removeable bits are a dress trim that exposes the 3 grub screws. I'll guess I'll know more once its been persuaded off with an angle grinder :)
Wont get a chance this weekend (netball carnival) but I'll post once I give it a go
PostPosted: Thu Nov 24, 2022 11:24 am
Finally got a chance to remove the lever from the car... once removed, I tried removing the gear lever knob with a drill (which failed)... then stepped upto a dremel with large cutting disk.. but wasnt able to remove it until an angle grinder came in. The heat from grinding made the epoxy melt, enabling it to be twisted off.
Judging by the short lever with no thread, I'm assuming the knob had been intentionally glued as a repair.
A new lever, knob and gaiter later, its all fixed.
Also replaced the remote housing mount which turned out to be split in 2... that would explain the over excited shaking at lights.
PostPosted: Thu Nov 24, 2022 2:27 pm
Those gearbox mounts usually break as a result of worn engine stabiliser bar bushes. Check yours.
PostPosted: Thu Nov 24, 2022 8:36 pm
Good point - I'll add to the list to things :)
The engine stabilisers appear to have been replaced when it was restored 12 years ago - they are red nolathane versions. The remote mount was marked MOWOG, so I'm assuming it was original
PostPosted: Thu Nov 24, 2022 8:53 pm
Nice work, I'm sure that'll make it nicer to shift and less vibration. Sounds like the gear know was put on very well.
PostPosted: Sat Nov 26, 2022 7:28 am
They also shear off if the bracket is not pushed hard forward against the mount.
PostPosted: Sun Nov 27, 2022 7:17 am
Is the bracket supposed to have slots in it, or perhaps this changed over time ? Mine doesn’t have slots for the body side mounting and it has always been a pig of a thing to install and remove.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Sun Nov 27, 2022 9:27 am
Yep it was a bit of a challenge to install. my bracket was exactly like this one https://minisport.com.au/mini-remote-ge ... ng-bracket
Attached is another angle of the mount install for reference
PostPosted: Sun Nov 27, 2022 12:19 pm
The 3 body mount holes in the bracket are slotted.
PostPosted: Sun Nov 27, 2022 1:25 pm
Here’s the one I took off mine
PostPosted: Sun Nov 27, 2022 1:51 pm
Wow. Genuine Australian new old stock part at some stage given the JRA parts & accessories label.
Users browsing this forum: No registered users and 37 guests
