https://ausmini.com/forums/
Rear subframe mount bushes
https://ausmini.com/forums/viewtopic.php?f=2&t=101611
Author:  clip [ Mon Nov 28, 2022 8:52 am ]
Post subject:  Rear subframe mount bushes
I have to replace the rear subframe bushes and have a set of Mini Sport black poly type that the previous owner must have bought but never fitted. Should I just use these, or buy a rubber set?
Author:  drmini in aust [ Mon Nov 28, 2022 9:09 am ]
Post subject:  Re: Rear subframe mount bushes
These days I would use poly. As the quality of 99% of rubber is rubbish and cracks up prematurely.
Ditto front lower arm rubber bushes.
Author:  clip [ Mon Nov 28, 2022 10:06 am ]
Thanks Dr. That saves me a few $ too.
I see you’ve got a Peak ignition fitted too. I couldn’t believe the difference it made to my setup. Can’t rate them highly enough, but I believe they’ve gone out of them now?
Author:  drmini in aust [ Mon Nov 28, 2022 5:31 pm ]
I believe so. :?
Lomin (Lindsay Seibler) might update if there's any change likely.
Author:  AWOODY [ Mon Nov 28, 2022 6:48 pm ]
I would use the rubber mine had the poly in it and they COMPLETELY disintergrated .
Author:  TK [ Mon Nov 28, 2022 10:38 pm ]
what about solid bushes?
Author:  drmini in aust [ Tue Nov 29, 2022 1:05 pm ]
If they were the old red poly from yesteryear I would agree, they were crap.
My steady bar ones did the same.
But recent black poly bushes seem fine.
Author:  AWOODY [ Wed Nov 30, 2022 6:38 pm ]
Doc they were purple ? From memory.
Author:  13secmini [ Thu Dec 01, 2022 9:15 am ]
I installed these and can't complain. holding up well.
Whiteline W92135
https://automotivesuperstore.com.au/whi ... XPzXEqXPZc
