https://ausmini.com/forums/
Mini Tie Rod End
https://ausmini.com/forums/viewtopic.php?f=2&t=101601
Author:  cooperess [ Sun Nov 20, 2022 5:22 pm ]
Post subject:  Mini Tie Rod End
Approximately how many turns should each tie rod end be screwed to the steering rack?
Author:  timmy201 [ Sun Nov 20, 2022 5:29 pm ]
Post subject:  Re: Mini Tie Rod End
A minimum of 1.5 times the thread diameter, then so they’re equal and the toe is right
You can get extended ones for a bit more thread engagement
Author:  9YaTaH [ Mon Nov 21, 2022 8:19 am ]
Step 1: measure the length of tie rod end you are replacing and compare to the replacement (to check they are the same)
Step 2: count the turns when you remove the old unit
Step 3: Fit the new unit by winding it on the number of turns you previously counted
Step 4: To be sure, get the toe in/out checked
