It is currently Thu Jun 26, 2025 8:19 am
PostPosted: Tue Nov 22, 2022 8:42 pm
Hi
I am new to mini and I just bought a mini deluxe. The brake pedal has no pressure so want to try to bleed the brake.
I couldn’t find the bleeding nipple on front drum brake. It has 2 brake wheel cylinder.
Anyone can tell me where they are and how to bleed them if there is no bleed nipple? Thanks
PostPosted: Tue Nov 22, 2022 8:48 pm
Umm.... they’re part of the wheel cylinders that sticks out of opposite side of the backing plate to that shown in your photo.
Cheers, Ian
Ps before you try bleeding make sure you replace the drum.
PostPosted: Tue Nov 22, 2022 9:42 pm
I can only see 2 shoe adjusters.
PostPosted: Tue Nov 22, 2022 10:23 pm
Here
PostPosted: Wed Nov 23, 2022 7:25 am
In your second post first picture the nipple will be behind the track rod, hidden in the photo.
Cheers Dave.
PostPosted: Fri Nov 25, 2022 5:48 pm
If you're new to minis, and working on old cars in general (which it sounds like you are), it's always best to get it properly serviced by a mini specialist mechanic so you know you have a safe and roadworthy car - especially when it comes to brakes
