https://ausmini.com/forums/
Alternator/Regulator Wiring
https://ausmini.com/forums/viewtopic.php?f=2&t=101592
Author:  surtees [ Mon Nov 14, 2022 2:05 pm ]
Post subject:  Alternator/Regulator Wiring
Hi All,
I'm tidying up some of my wiring and found a Brown with green trace wire off the Regulator that doesn't go anywhere. Where is it meant to go?
On the Alternator is a brown/White trace and it works on the ignitions light on Speedo. And the charge cable going back to the battery box/start solenoid.
Author:  gtogreen1969 [ Mon Nov 14, 2022 2:35 pm ]
Post subject:  Re: Alternator/Regulator Wiring
The F wire would be disconnected if the new alternator is internally regulated and the 8TR is still fitted.
Author:  surtees [ Mon Nov 14, 2022 3:05 pm ]
Thanks GTO, yes it's got a later Rover internal regulator Alternator fitted. So looking at the diagram the 8TR can be removed. I was getting confused why it had an internal and external reg......
Author:  drmini in aust [ Mon Nov 14, 2022 4:49 pm ]
If the external regulator is removed just tape the wire up, it only goes to the regulator multipin connector.
Author:  surtees [ Mon Nov 14, 2022 6:09 pm ]
Yes Doc I'll tidy it up, no wants things grounding and letting the smoke out.
