It is currently Fri Jun 27, 2025 11:13 am
 Post subject: 1969 mini k
PostPosted: Wed Oct 19, 2022 11:27 am
Syncro gone on second gear, what's a ball park figure to get it fixwd ?
Allen
 Post subject: Re: 1969 mini k
PostPosted: Wed Oct 19, 2022 12:11 pm
I guess it depends a lot on how much you do yourself
Dropping off a running car for the job will obviously add a lot of time and money in labour
If you did it all yourself and only replaced the synchro ring, it’d be a couple hundred once you take into account the gaskets, oil, coolant etc. There’s a decent chance that other things will need to be replaced while it’s apart and most shops won’t put it back together unless it’s all rebuilt and warrantable
PostPosted: Wed Oct 19, 2022 1:25 pm
Agree with Timmy, It's a bit of how longs a piece of string. Even doing it yourself once you get it open what else you find.
PostPosted: Wed Oct 19, 2022 4:04 pm
OK thanks ,it is not my car ,what would a rebuilt box cost including all labor and parts ?
Allen
PostPosted: Wed Oct 19, 2022 7:57 pm
i have herd of gear boxes costing upwards of 3000
PostPosted: Thu Oct 20, 2022 8:30 am
I handed my gearbox to a reputable mini rebuilder 18mths ago. It was already clean and all new bearings, layshaft & laygear (NOS) supplied. He replaced 1st gear, all baulk rings, thrust washers and it was around the $1300 region not including diff or gasket sets. So mostly labour (and by labour i mean knowledge), and a job well done i was happy to pay it even though I could have done it myself.
But that was my scenario, and i would suggest that would be a ball park minimum. If they are pulling the engine and find other things you can start multiplying that number by 3,4,5…. As Timmy suggests it would be a false economy to not check other things while the engine is out & split.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
