Is the speedo a UK (Mk1) or an Aust''n (mk2)?
This is a UK Mk1 speedo - the gear wheel is the white plastic piece in this photo, beside the yellow 1/10 mile wheel. This gearwheel doesn't change the speedo ratio.
These speedos were made with a fixed ratio listed on the face of the speedo to indicate the number for turns of the drive wire to equal 1 mile e.g. 1280 turns for a 1275 cooper S. See below
The coloured gears to change ratios were in the speedo housing where the speedo drive cable attached. These different coloured gears only need swapping when changing a speedo to a different car with different gearbox ratio/wheel sizes.
Some specialist repair places may have spares - the gear wheel and the pawl to click it over are the main wearing parts here. Otherwise, can you glue the wheel together?
