What are your thoughts on this (distributor restoration) https://ausmini.com/forums/viewtopic.php?f=2&t=101425 |
Author: | carter [ Wed Jul 13, 2022 5:14 pm ] |
Post subject: | What are your thoughts on this (distributor restoration) |
Hello ausminiers, I have been told this is basically a bin job. Asking if its fixable and worth fixing. How would one go about it and are all the weights etc still available to buy? |
Author: | timmy201 [ Wed Jul 13, 2022 6:49 pm ] |
Post subject: | Re: What are your thoughts on this |
You can get all the internal moving parts from another distributor, or a specialist distributor rebuilder. I’ve seen people repair the lower collar by making up a spacer ring with some grub screws. It’d be worth fixing an original 23D for a Cooper S if it’s the right stamping. https://mk1-forum.net/viewtopic.php?f=3 ... 5&p=277965 |
Author: | carter [ Wed Jul 13, 2022 7:14 pm ] |
thanks for that I havent seen that before. It is an original mk 1 s dizzy. |
Author: | simon k [ Fri Jul 15, 2022 2:10 pm ] |
I built dad's mk1 distributor up with epoxy metal putty and filed it back, still fine many years later (I think) Machining up a collar like timmys photo is a good idea |
Author: | carter [ Fri Jul 15, 2022 7:06 pm ] |
where do you get that stuff simon? |
Author: | cgo [ Fri Jul 15, 2022 7:56 pm ] |
I had one repaired by the machine shop of Dad over 20 years ago. It had a broken collar due to an over tightened clamp. It was welded and then machined to standard size. |
Author: | GR [ Fri Jul 15, 2022 8:10 pm ] |
HI Carter Don't bin it i weld them up and re machine them or turn it down make a collar a nice fit and locktite it works fine. As for the in sides as Tim said take it out of another dizzy, if the bushes are worn you may have to make them as i don; think you can buy them any more. Graham Russell |
Author: | simon k [ Sat Jul 16, 2022 9:44 am ] |
carter wrote: where do you get that stuff simon? Anywhere.. Supercheap etc. all have it |
Author: | carter [ Sat Jul 16, 2022 4:11 pm ] |
Cool thanks Simon |
Author: | simon k [ Sat Jul 16, 2022 4:34 pm ] |
carter wrote: Cool thanks Simon this is the kind of stuff I used -> https://www.bunnings.com.au/selleys-50g ... lsrc=aw.ds but again, if I was to do it again (and maybe I will next time Dad has his car up here) I'd do it as per Timmy's picture. Makes way more sense.. The way that clamping shoulder thingy isn't solid is just dumb, it's like it's designed to break |
