4 Synchro Gear Box Case Differences https://ausmini.com/forums/viewtopic.php?f=2&t=101423 |
Author: | cooperess [ Tue Jul 12, 2022 12:10 pm ] |
Post subject: | 4 Synchro Gear Box Case Differences |
Attachment: Mini 22G1128 Gear Box DSCF1366.JPG Apart from the stamped numbers on the left, what is the difference from a Mini 4 synchro box and a Coopers S 4 synchro box?
Author: | TK [ Tue Jul 12, 2022 12:35 pm ] |
Post subject: | Re: 4 Synchro Gear Box Differences |
Gear ratios, Hardy Spicer outputs |
Author: | cgo [ Tue Jul 12, 2022 2:46 pm ] |
Post subject: | Re: 4 Synchro Gear Box Case Differences |
The 1st motion shaft gear with 18 teeth is a major difference and a Cooper S Laygear. |
Author: | simon k [ Wed Jul 13, 2022 9:41 am ] |
Your title says "case differences" and you said "apart from the stamped numbers", the answer is "absolutely nothing" |
Author: | cooperess [ Wed Jul 13, 2022 10:58 am ] |
Just want to be sure that a non FAXE case is ok to fit a Mk2 engine. |
Author: | simon k [ Wed Jul 13, 2022 11:17 am ] |
Yep, no problem at all. The only tangible difference in the gearbox case assembly is the diff side plate covers, but obviously they're very interchangeable. I have pot joints on my FAXE case *cough*IdohaveaspareFAXEcaseifyouwantonethough*cough* |
