Mini Wiring Loom https://ausmini.com/forums/viewtopic.php?f=2&t=101420 |
Page 1 of 2 |
Author: | cooperess [ Mon Jul 11, 2022 2:46 pm ] |
Post subject: | Mini Wiring Loom |
Just bought a Vinwiring loom and was wondering what root the dash wiring should take. There are 3 holes in the front parcel tray. Should all the 3 wiring branch go through the larger centre whole or should they be split the utilise the remaining smaller outer holes for the lesser wires. Attachment: Mini Vinwiring Loom DSCF1364.JPG
Author: | IndigoBlueCooperS [ Mon Jul 11, 2022 7:20 pm ] |
Post subject: | Re: Mini Wiring Loom |
All wiring should go through the central hole - nothing in the other holes. |
Author: | DavidE [ Mon Jul 11, 2022 8:13 pm ] |
IndigoBlueCooperS wrote: All wiring should go through the central hole - nothing in the other holes. and don't neglect to put a large holey grommet in the hole first. |
Author: | cooperess [ Tue Jul 12, 2022 10:25 am ] |
DavidE wrote: IndigoBlueCooperS wrote: All wiring should go through the central hole - nothing in the other holes. and don't neglect to put a large holey grommet in the hole first. |
Author: | timmy201 [ Tue Jul 12, 2022 10:33 am ] |
My 850 book has it as 3H1457 (GROMMET 1-3/8 x 3/4). |
Author: | Bill B [ Tue Jul 12, 2022 10:36 am ] |
DavidE wrote: and don't neglect to put a large holey grommet in the hole first. Where can I buy the holey grommet from and/or what is the part number.[/quote]I'd like to know where to get one of those too - can't find anyone selling that size. And realise the clubman minis had a large diameter grommet than round nose. |
Author: | OGW1152 [ Tue Jul 12, 2022 11:43 am ] |
Hello All, I'm not sure of the dimensions, but would Lucas grommet #C555 be close? Regards, Glen |
Author: | DavidE [ Tue Jul 12, 2022 12:47 pm ] |
Bill B wrote: DavidE wrote: and don't neglect to put a large holey grommet in the hole first. Where can I buy the holey grommet from and/or what is the part number.I'd like to know where to get one of those too - can't find anyone selling that size. And realise the clubman minis had a large diameter grommet than round nose.[/quote] I bought from a local rubber goods supplier based on size. |
Author: | cooperess [ Tue Jul 12, 2022 2:01 pm ] |
So the grommet is 35mm x 19mm, is that a correct calculation? |
Author: | Oscar [ Tue Jul 12, 2022 2:27 pm ] |
Clark Rubber sells grommets as per the following list... |
Author: | Andosoft [ Tue Jul 12, 2022 2:30 pm ] |
I found something that worked from Clark rubber. I think it was a blank that I cut a x in Ah, I see Oscar beat me to it. |
Author: | Bill B [ Tue Jul 12, 2022 2:35 pm ] |
Thanks Rod. I found they list 15728 as 34.5mm X 20mm, which is close to the panel hole size. When you search their site, computer says "Nah" - as in "no record". |
Author: | Oscar [ Tue Jul 12, 2022 3:06 pm ] |
No wuks Bill. They are available mate. You just have to blunder around a bit ![]() I'm glad I found this listing as I need a handful of varying sizes for a Pulsar GTIR project I'm playing with atm! |
Author: | cooperess [ Tue Jul 12, 2022 3:59 pm ] |
I think I've found where I can get the right sized grommet for my parcel shelf wiring loom hole. The hole is 35mm in diameter and Clark Rubber chart above shows a thin grommet Item no. 726 which appears to have all the right measurements. Thank you all for your input. |
Author: | Bill B [ Tue Jul 12, 2022 10:25 pm ] |
Oscar wrote: No wuks Bill. They are available mate. You just have to blunder around a bit ![]() I'm glad I found this listing as I need a handful of varying sizes for a Pulsar GTIR project I'm playing with atm! You're a better web blunderer than me Oscar. Still no listing from Clark Rubber. If I have to click and collect at Geelong from Sydney, I might need 36 months of interest free payments. |
