Blinker Horn & Light Connector https://ausmini.com/forums/viewtopic.php?f=2&t=101397 |
Author: | cooperess [ Fri Jun 17, 2022 7:06 pm ] |
Post subject: | Blinker Horn & Light Connector |
There seem to be no outlets for the female connector for the 13H7779 part, at least not on google. I am trying get one, can any one help? |
Author: | Bill B [ Sat Jun 18, 2022 10:45 pm ] |
Post subject: | Re: Blinker Horn & Light Connector |
Not quite sure what you are after. Is it this part of the connector block that joins the blinker switch to the main harness? Attachment: Blinker joiner block Clubman.jpg If it is, these were mostly used in clubman minis. Mk2 S and mini K used a 6-gang joiner like this: Attachment: Blinker switch joiner.jpg The 13H7779 blinker switch comes with the clubman terminal block. For originality, the switch stalk is almost identical but to fit to a Mk2S or K, the wires need to end with bullet terminals which push into the red 6-gang joiner. Some of the wires used to control high/low beam at the blinker switch have been cut by the factory for S and K application. |
Author: | cooperess [ Sat Jun 18, 2022 11:07 pm ] |
That's the one Bill = the top black plastic one. |
Author: | Bill B [ Sun Jun 19, 2022 10:12 am ] |
Send me an email or pm if you still want it. These were not used on Mk2 S - they had the red sleeve joiners. The wiring harness should have the leads for the blinker unit ending in bullet terminals - not female spade connectors which were used in clubman harnesses. |
