It is currently Fri Jun 27, 2025 1:54 pm
 Post subject: parasite battery drain
PostPosted: Tue Jun 14, 2022 11:04 am
I have a 1972 Clubman with Lucas ACR15 internally regulated alternator.
Recently i left the car in a garage for 3 weeks and the battery went dead flat.
The only non standard item drawing current is a cd player which has a yellow "hot all the time" wire to power the cd player clock, memory etc.
I suspected some parasite current drain and found a 40-50mA discharge. Taking the fuses out was unhelpful so I disconnected the power lead from the alternator. Battery drain dropped to 8mA, a more realistic figure for a cd clock.
So I surmise that there is an internal fault in the alternator.
Does anyone have experience of such things? Is it a crook diode? Is there an easy fix?
Auster3
PostPosted: Tue Jun 14, 2022 6:43 pm
It could well be a diode failing in the regulator or a transistor . The internal regulators for the 15 / 16 ac are becoming hard to get. I replaced the whole alternator with a 17 acr which also has the benefit of greater output as well as readily available parts.
Cheers Dave.
PostPosted: Wed Jun 15, 2022 11:16 am
I had the same problem, a NOS UK made alternator I bought 20 years ago fixed it.
New alternators are so cheap it's not worth fixing old, unless it's a real S...
Users browsing this forum: No registered users and 66 guests
