It is currently Mon Jun 30, 2025 1:00 pm
 Post subject: 2 Speed Wiper Wiring
PostPosted: Fri May 27, 2022 2:29 pm
Looking for help on how to remove the wiring so I can rewire.
If this is not possible, where can I get this fitting?
 Post subject: Re: 2 Speed Wiper Wiring
PostPosted: Fri May 27, 2022 3:09 pm
You need to move the crimp locking tab down with a small screwdriver so that the crimp can be pulled out. The photo shows the one with a tab on the left and a non-locking one on the right.
1970 Morris Mini K
PostPosted: Fri May 27, 2022 10:33 pm
One of those tiny flat screwdrivers helps in getting access to the tang.
PostPosted: Sat May 28, 2022 6:57 am
the stainless strips that are in some wiper blades are also useful - NB there are 2 widths and the narrower one is the best. I have found that these strips do less damage to the plug than the screwdriver.
PostPosted: Sat May 28, 2022 9:19 am
It too difficult to remove the pins.
Where are can I get a replacement plastic connector?
PostPosted: Sat May 28, 2022 11:46 am
Neither my mid- '69 mini K (single speed) nor 8/70 S (2 speed) have the terminal block. The wiring ends in those moulded black plastic insulators, so they are factory original.
PostPosted: Sat May 28, 2022 12:45 pm
Maybe my wipers are only single speed.
LUCAS AUSTRALIA 62971039A 12AUW 4-69 with 4 wires 110 Degree.
PostPosted: Sat May 28, 2022 12:48 pm
This shows the moulded black plastic connectors on my 8/70 S with 2 speed wipers that Bill is talking about. Well, at least the remains after rats had feasted on the wiring insulation.
The moulded connector block appeared sometime in the Clubman/Leyland Mini era.
PostPosted: Sat May 28, 2022 12:50 pm
LUCAS AUSTRALIA 62971039A 12AUW 4-69 with 4 wires.
Four wires suggest two-speed wipers. The first production use was on SPO41 cars from 8/70, so yours may have been fitted by a previous owner.
PostPosted: Sat May 28, 2022 1:02 pm
The cover suggests one speed.
PostPosted: Sat May 28, 2022 1:12 pm
Wrong cover?
Is the wiper switch a two-speed type?
PostPosted: Sat May 28, 2022 2:08 pm
That would make sense to incorporate a terminal block for the harness once 2-speed motors became standard and not just used in special production runs.
My single speed Lucas Aust motor only has 3 terminals on the motor and 3 wires attached to them so 4 terminals is a good indication of being 2-speed.
PostPosted: Sat May 28, 2022 2:11 pm
Wrong cover? That's my thinking.
Is the wiper switch a two-speed type? I have bought a 2 speed switch thinking is a 2 speed wiper.
PostPosted: Sat May 28, 2022 7:53 pm
Three wiper wires with black terminals from my 3/70 S wiring loom. Originally it also had a single speed wiper and switch. I have modified a spare wiper motor to be two speed and have bought a two speed switch. I will probably just add and extra wire (with black terminal) to make the 2 speeds work - will look more original. The other pictures show the clubman 4 pin plug and loom I bought ages ago, which is the same as the plug you pictured.
PostPosted: Sat May 28, 2022 8:35 pm
I just made a connector removal tool with a modified hack saw blade.
