It is currently Mon Jun 30, 2025 6:49 am
 Post subject: MK1 Dash setup
PostPosted: Sun May 29, 2022 8:49 pm
Hey all,
Im wanting to add water/oil gauges & possible tacho etc to my mk1 that still has a centre speedo.
I like the idea of the Mk2 oval type dash piece - but before i pull the trigger on that, id like to see alternate ways of installing gauges while keeping the open parcel shelf/dash.
If you could share pics of your mk1/mk2 dash to help inspire me for dash ideas.
Thank you
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: MK1 Dash setup
PostPosted: Sun May 29, 2022 11:37 pm
Lots of hard work for this one.
This one from Nippy Cars in the UK - expensive but a classic.
Or this one - also costs money.
But the Mk2 is one of the cheaper options as they were fitted to the Mini K and can be found second hand.
PostPosted: Mon May 30, 2022 7:05 am
I’ve got mine under the dash rail on the drivers side
PostPosted: Mon May 30, 2022 8:36 am
I was looking at the oval binnacle as well because i have the cooper backplate and brackets, but in the end opted for a home made wooden dash. I used an original walnut dash as a template and customised it for the gauges.
Also means i can hide all my cr@p (so my wife says) in the glove box (fuses, bulbs, spare wire, notepad)
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Mon May 30, 2022 2:49 pm
I made up a bracket and put 3 gauges in it - water temp, oil pressure and revs - and mounted it in the centre under the parcel shelf.
I've got the temp and oil gauges on either end and the tacho is in the middle. I don't look at that one all that often. Depending on if the key ring is hanging down, I move it a bit. Mostly, I hook the key ring up over one of the switches. I do need to move my head a bit when I'm driving to see them but for me, they work well. My thinking was that I wanted something that looked like what would have been done say in the 60's or 70's. White gauges match with the white speedo.
Cheers, Rocky
Users browsing this forum: jpodge and 77 guests
