It is currently Sun Jul 06, 2025 7:29 pm
PostPosted: Mon May 16, 2022 11:27 am
This is the tail of the diff housing on a remote gearbox.
There is a small rectangular cutout that, when bolted to the remote housing, leaves a gap on the top side, where oil and grit can enter.
I can't remember what should be in that gap and parts catalogues don't seem to mention it.
PostPosted: Mon May 16, 2022 11:56 am
This might be it - number 66 in the illustration or 22A1373
https://www.somerfordmini.co.uk/manual- ... earchanges
PostPosted: Mon May 16, 2022 11:57 am
PostPosted: Mon May 16, 2022 12:39 pm
eightfifty wrote:
Bill! Your cover plate AYA3035 (mentioned in parts books but not illustrated) appears not to be made to the drawing! regards Tony
Thanks Tony. I had forgotten that too.
When I bought the car in 1975 it had already had engine work done to it and that plate was missing.
Since I didn't have access to tech drawings at the time, I had to make my own. It may not be original but at least it has kept the muck out of the linkages.
PostPosted: Mon May 16, 2022 12:49 pm
Thanks Tim.
That has prodded the memory into functioning. Can now remember trying to fit the remote housing and not letting that rubber filler strip from falling into the housing.
I also seem to remember the rubber turning to mush due to the oil and grease in there.
Will make something suitable.
PostPosted: Tue May 17, 2022 5:17 pm
Thanks Bill, my two gearboxes are missing said plate. Time to make a couple. Thanks eightfifty for the drawing.
PostPosted: Thu May 19, 2022 8:21 pm
Does anyone know what the purpose of the slot rebated into the mating surface next to the large hole that is covered by the metal plate? I have had a couple of housings like this and it must be factory, but the slot creates an opening that seems to rather defeat the point of sealing all the other holes up. I had wondered if it was added to provide some 'breathing' after the metal plate was introduced.
