Having a car stolen is an real downer, even worse if, as in the 3 times it has happened to me, the car was torched as well. It is not just the theft of the vehicle but the loss of other personal items as well as the horrible feeling of paranoia the follows. My route to mini and other vehicle security has a few angles. Visual deterrent via very visible steering locking devices, bonnet locks which are a lot easier on a clubman then a roundnose, ignition and fuel cutoff devices, battery isolators and an entry alarm with the 120db screamer siren mounted in the car cabin (trust me when I say that no one can even think when that is causing your ears to bleed.) It is very much horses for courses, 10 different people will probably have 20 different ideas. If it works for you then it is a good idea. Others may like different solutions.
_________________ Cheers Dave.
