timmy201 wrote:
Do you have a fuel filter in the line somewhere?
With the current pump (ecco) I installed a ryco Z4 between the tank and pump
timmy201 wrote:
Have you checked the fuel bowl has fuel in it now?
Yes
timmy201 wrote:
What spring are you using in the carb?
Red
timmy201 wrote:
Have you checked the fuel bowl level?
I have not checked the actual float level, I should probably do that
timmy201 wrote:
Have you confirmed the timing with a timing light?
Yes, when I set the timing light to the degrees the black box says it is running the mark on the pulley lines up with the first tooth. I have also checked with a basic timing light which also tells me it is correct
timmy201 wrote:
Is the blackbox rpm approximately the same as the timing light/tacho?
Yes
timmy201 wrote:
I know it’s a pain with the cb blackbox as it needs a different offset angle, but it might be worth bypassing the blackbox so you can get it running right first to eliminate one potential factor. If you time it at approximately 10 degrees of base timing, get it running and rev it up with the timing light hooked up to confirm the timing is stable and doesn’t advance or retard
Yes, of course I want to avoid having to bypass the black box.
timmy201 wrote:
Have you got a reasonably good battery & is the alternator working too? One problem I had with my blackbox (the Accuspark type) was that it didn’t work under 10v
I had suspected that was the issue as I was using an old battery so I bought a new one which made no difference.
