It is currently Thu Jun 26, 2025 4:05 am
PostPosted: Sun Dec 04, 2022 4:46 pm
Just would like to know the correct positioning of the twin SU carby fuel feed pipe.
PostPosted: Sun Dec 04, 2022 7:04 pm
Rightly or wrongly so, mine is #2 with another strap going around the pipe and secured by the accelerator cable bracket nut.
PostPosted: Sun Dec 04, 2022 10:58 pm
Yeh run the fuel pipe closest to the rocker cover.
There is a short P clip that supports the fuel pipe at the PCV valve and another longer P clip at the other end.
The Accelerator Cable bracket goes on first then the short P clip then the PCV valve bracket.
Here are some pics if needed
