2 Speed wiper motor wiring https://ausmini.com/forums/viewtopic.php?f=2&t=101230 |
Author: | DTrain [ Thu Feb 10, 2022 7:44 am ] |
Post subject: | 2 Speed wiper motor wiring |
Hi all, Just recently replaced the wiper contact ring and contact assembly, and at the same time opened up the wiper switch and cleaned the contacts. Its probably a lesson in taking photos of everything but thought I would post to help others. I disconnected the wiring 10+ years ago but worked out it should go back like the photo below The other thing to ensure is that the number contacts on the back of the wiper switch need to be ascending from the bottom up, i initially put it back together with no1 at the top and 5 at the bottom, however it needs to be the other way - this ensures the self park (no1) is in contact with earth (no2) in the off position....and so on. Hope this helps |
Author: | DavidE [ Thu Feb 10, 2022 8:20 am ] |
Post subject: | Re: 2 Speed wiper motor wiring |
DTrain wrote: Hi all, Just recently replaced the wiper contact ring and contact assembly, and at the same time opened up the wiper switch and cleaned the contacts. Its probably a lesson in taking photos of everything but thought I would post to help others. I disconnected the wiring 10+ years ago but worked out it should go back like this --> https://photos.app.goo.gl/spadoTr6EmKv3oLZ9 The other thing to ensure is that the number contacts on the back of the wiper switch need to be ascending from the bottom up, i initially put it back together with no1 at the top and 5 at the bottom, however it needs to be the other way - this ensures the self park (no1) is in contact with earth (no2) in the off position....and so on. Hope this helps I like this diagram, which worked out just right for me. Attachment: 75204635_701162577050706_4817214527256920064.jpg
Author: | ozmini [ Thu Feb 10, 2022 10:17 am ] |
I found this somewhere on the interwebby the other day - thought it was a good resource to have as it has the 3 most common setups foe Mini Wiper wiring. Attachment: 12AUW-Wiring.jpg
Author: | DavidE [ Thu Feb 10, 2022 11:23 am ] |
ozmini wrote: I found this somewhere on the interwebby the other day - thought it was a good resource to have as it has the 3 most common setups foe Mini Wiper wiring. Attachment: 12AUW-Wiring.jpg That was me posting that as well/ |
Author: | gtogreen1969 [ Thu Feb 10, 2022 11:31 am ] |
Thats an earlier version where I left the Green/Yellow in at terminal C. It was listed as that in the wiring diagrams but in the real world that colour is Red/Light Green. Here is the latest one Attachment: 12AUW-WIPER-MOTOR-WIRING-ALL-MODELS (Latest).jpg
Author: | Steam [ Thu Feb 10, 2022 3:40 pm ] |
The colours can also be confusing as they change at the fingers/motor. |
Author: | surtees [ Thu Feb 10, 2022 3:50 pm ] |
On the topic of 2 speed Wiper meters I've got 2 later motors . To fit them to a 66 Rh park is it a matter of changing the Wiper rack tubing to suit? Do I need to change to a RH park drive cable? Looking at the mounting it appears I can use two of the mounting holes and then drill one mounting hole.for the out bound one? And wire up using the above. |
Author: | timmy201 [ Thu Feb 10, 2022 4:33 pm ] |
Gambo did a good “how to” guide here viewtopic.php?f=2&t=100848 |
Author: | surtees [ Sun Feb 13, 2022 1:22 pm ] |
Thanks Timmy that's great |
