Rear subframe Question https://ausmini.com/forums/viewtopic.php?f=2&t=101188 |
Author: | Bill B [ Fri Jan 21, 2022 5:17 pm ] |
Post subject: | Rear subframe Question |
For anyone who has worked on a rear subframe assembly recently... Attachment: Inked20220121_144338_resized_LI.jpg What size of washer would be fitted to the support pin, under the nyloc nut (blue arrow)? The parts catalogue says PWZ207 (same as the flat washer on the front tie bar) but that washer is even too big to fit in the space available. I'm guessing a much smaller washer. I realise this is a petty issue, but I've come this far. |
Author: | DavidE [ Sat Jan 22, 2022 5:51 am ] |
Post subject: | Re: Rear subframe Question |
Bill B wrote: For anyone who has worked on a rear subframe assembly recently... Attachment: Inked20220121_144338_resized_LI.jpg What size of washer would be fitted to the support pin, under the nyloc nut (blue arrow)? The parts catalogue says PWZ207 (same as the flat washer on the front tie bar) but that washer is even too big to fit in the space available. I'm guessing a much smaller washer. I realise this is a petty issue, but I've come this far. I'd be fitting one with the largest OD that will fit in that space. |
Author: | winabbey [ Sat Jan 22, 2022 12:51 pm ] |
PUB1012 parts book shows both PWZ107 and PWZ207 for that washer (items 31 and 33), so obviously a misprint. Attachment: PUB1012 Q02 L.jpg Attachment: PUB1012 Q02-1 R.jpg It seems PWZ107 is correct as it has a smaller outside diameter. Attachment: BMC_Std_Parts_Fasteners_7.jpg Dimensions of PWZ107 here - https://www.somerfordmini.co.uk/washer- ... 78-ext-dia |
Author: | Bill B [ Sat Jan 22, 2022 1:53 pm ] |
Thanks DavidE - that is what I ended up doing. As Winabbey said, my Mini King catalogue listed all 4 washers under the "Large O.D." part number. Another of life's little mysteries sorted..... Thanks. |
