It is currently Tue Jul 08, 2025 2:48 am
PostPosted: Mon Dec 27, 2021 10:56 pm
I was hoping someone would point me to a posting on Ausmini that I noticed some time ago. The post provided advice on the order to do things when putting a Mini back together after a restoration.
Greg.
PostPosted: Tue Dec 28, 2021 11:43 am
Not sure if this is what you are looking for. I assume you are rebuilding from a bare shell and not just meaning the engine & gearbox. It's pretty generalised and skips over many details.
viewtopic.php?f=2&t=32880&hilit=order+of+reassembly
I am in the same position. Just flatting and compounding the paintwork before I put too many parts onto the shell. Have fitted hydro, brake, fuel pipes and battery lead to underside so far. Subframes will be next, with some things pre-fitted and others fitted later.
