Striker/Latch/Buffer differences https://ausmini.com/forums/viewtopic.php?f=2&t=101139 |
Author: | 1071 S [ Tue Sep 07, 2021 7:03 pm ] |
Post subject: | Re: Striker/Latch/Buffer differences |
Hi Louis, I must admit it was many years ago but when I did the reverse (replaced the Oz windups fitted to my (UK) Traveller with proper sliding window doors) I just unscrewed the buffer and bracket and swapped them over. While Oz cars have the buffer on the body and UK cars have them on the door, the screws are in the same place so one just attaches in place of the other. I don't know if Oz brackets/buffers are different from the UK version but I would suggest that as long as you have a matched pair (buffer and bracket) it won't matter. I didn't know that Oz cars have fixed brackets ... how would you adjust them?? Unfortunately the only Oz car I have is an 850 - with sliding windows. I shall have to go down to the shed to check. As for the latch, I just used to one on the car.... So same latch works with windups or slider doors. I can measure the ones I have if you want ...say bolt hole to the locking ridge(s)?? Casual observation suggests they're the same as the ones on 1071. Let me know if I can help. Cheers, Ian |
Author: | winabbey [ Wed Sep 08, 2021 1:34 pm ] |
You say you want to fit Australian designed wind-up window doors to a UK body with sliding window doors. Do you already have a pair of Australian doors to fit? If so you should be able to see the difference around the lock area which would prevent you from simply fitting them to the UK body door aperture. The B pillars were modified on the Australian body to accommodate the different profile. You will need to do the same on your UK body. The usual method is to cut this section of the B pillar from a donor car and fit to the sliding window body. In my view only a brave or skilled body repair person would attempt to make this modification in any other way if a neat and original-looking factory result is the aim. Here are photos of a UK sliding window door and B pillar (green paint), and the same for an Australian wind-up window car (white paint). You can see the depression in the Oz B pillar and the style and position of the striker plates and buffers. I would suggest the position and fitting of the latter is the least of your concerns when doing this modification. Attachment: UK B Pillar.jpg Attachment: UK Door.jpg Attachment: Australian B Pillar.jpg Attachment: Australian Door.jpg
Author: | cooperess [ Wed Sep 08, 2021 5:24 pm ] |
Attachment: Dscf0874.jpg Here is my input
Author: | winabbey [ Wed Sep 08, 2021 9:35 pm ] |
Louis wrote: Just to clarify, this is for the earlier handle type (i.e. the ones which droop over time), not the later flappy handle burst proof type? Yes. |
Author: | winabbey [ Fri Sep 10, 2021 10:47 am ] |
Louis wrote: Winabbey, if the green mini is yours, would it be possible for a photo showing the other face of the striker plate from inside the vehicle? I am trying to gauge how much the latch engages against the striker plate based on paint wear. No, not my car, so I can't take other shots. And my own car is in storage. Hopefully someone else can assist. |
