It is currently Wed Jul 09, 2025 4:41 pm
 Post subject: Diff case locktabs
PostPosted: Sun Sep 05, 2021 5:49 pm
It seems most locktabs are NLA or the preference is loctite. I assume the same for the rear Diff cover. Just use spring washers and loctite ?
31 & 32 in pic
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
 Post subject: Re: Diff case locktabs
PostPosted: Sun Sep 05, 2021 5:52 pm
Some locktabs are available if you want to keep original.
https://minisport.com.au/search/?q=locktab
PostPosted: Sun Sep 12, 2021 5:17 am
I've never had problems using good spring washers and no Loctite.
That's all the lower RH stud on a remote box has, anyway.
Edit:
3/8 Nyloc nuts are a good idea too.
Users browsing this forum: Bill B, Bing [Bot], rocky&bullwinkle and 100 guests
