Rocker cover oil filler cap https://ausmini.com/forums/viewtopic.php?f=2&t=101114 |
Author: | Tomtax [ Sat Aug 21, 2021 3:31 pm ] |
Post subject: | Rocker cover oil filler cap |
Hi All Is it normal when you remove the oil filler cap for the rev’s to increase on a 1275s motor? How do you tell whether you have a vented or non vented cap Thanks |
Author: | drmini in aust [ Sat Aug 21, 2021 4:16 pm ] |
Post subject: | Re: Rocker cover oil filler cap |
Q1 Yes, the extra air into the manifold increases rpm. Q2 The vented cap has an air intake below the handgrip. Either cap type works. I have run one of each on my 1360 and 1412 stroker. |
Author: | winabbey [ Sat Aug 21, 2021 4:17 pm ] |
An image of both types here - https://minisport.com.au/search/?q=oil+ ... cap+vented The vented one is specified for closed circuit breathing, such as PCV. |
Author: | Tomtax [ Sat Aug 21, 2021 5:36 pm ] |
Thanks all |
