It is currently Sat Jun 28, 2025 8:40 pm
PostPosted: Sat Aug 21, 2021 3:31 pm
Hi All
Is it normal when you remove the oil filler cap for the rev’s to increase on a 1275s motor?
How do you tell whether you have a vented or non vented cap
Thanks
PostPosted: Sat Aug 21, 2021 4:16 pm
Q1
Yes, the extra air into the manifold increases rpm.
Q2
The vented cap has an air intake below the handgrip.
Either cap type works. I have run one of each on my 1360 and 1412 stroker.
PostPosted: Sat Aug 21, 2021 4:17 pm
An image of both types here - https://minisport.com.au/search/?q=oil+ ... cap+vented
The vented one is specified for closed circuit breathing, such as PCV.
PostPosted: Sat Aug 21, 2021 5:36 pm
Thanks all
