It is currently Sat Jun 28, 2025 5:20 am
PostPosted: Fri Aug 13, 2021 4:08 pm
Hi everyone,
Happy Friday!!
Can anyone help with a photo of where to mount a Malpassi Filter King fuel pressure regulator??
Also, do the only flow one way, as the connectors are opposite to how I would prefer them.
Many thanks in advance
PostPosted: Sat Aug 14, 2021 9:42 am
Frog Johnson wrote:
Hi everyone,
Happy Friday!!
https://www.youtube.com/watch?v=EDMnFvxrRzo
PostPosted: Sat Aug 14, 2021 6:36 pm
Thanks for that link, I’d seen that before.It doesn’t show where he ends up mounting it though. Although when he tests it he appears to have it flowing opposite to the markings on connections - so I guess that works
PostPosted: Sat Aug 14, 2021 7:15 pm
All the instructions are on the manufacturer’s website. Did you have the filter/regulator combo or just the regulator? Any reason why you need one?
http://www.officinamalpassi.it/en/regul ... etail.html
PostPosted: Sun Aug 15, 2021 11:29 am
Frog Johnson wrote:
Thanks for that link, I’d seen that before. It doesn’t show where he ends up mounting it though. Although when he tests it he appears to have it flowing opposite to the markings on connections - so I guess that works
Depends on your under bonnet space, the only other advice I could give is not anywhere over the exhaust manifold...
PostPosted: Sun Aug 15, 2021 11:39 am
Why would you need a regulator on a mini , standard fuel pumps don't require one , I used the standard SU pump on my 1400cc speedway mini for about 5 years with no problems
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sun Aug 15, 2021 3:08 pm
You’re all right. I don’t need it.
I must have misread the pressure gauge when I put the pump on.
