It is currently Sat Jun 28, 2025 12:28 pm
 Post subject: Steering Rack Bush
PostPosted: Fri Aug 20, 2021 7:26 pm
Hi All,
Is there a definite orientation to fit the hex bush in relation to the three machined areas on the rack housing? Corners aiming at the cutouts on the rack or flat edges?
 Post subject: Re: Steering Rack Bush
PostPosted: Fri Aug 20, 2021 8:16 pm
I line up the flats with the metal bits. Unless the shaft has been gouged by the grubscrew, then I turn the bush just enough to miss it
PostPosted: Sat Aug 21, 2021 5:35 am
Thanks Kev.
