Brake light wiring https://ausmini.com/forums/viewtopic.php?f=2&t=101054 |
Author: | Harwox [ Wed Jul 14, 2021 9:28 pm ] |
Post subject: | Brake light wiring |
Loving this page. After been stalled for a few months on finishing a 68 Leyland project someone else had started I have already had some good wins since the page was restored, getting me on track for RWC this weekend. My one sticking point is the passenger stop light. I can see that the wire is not connected to the terminal, so should be an easy fix. Is there a way to remove the light assembly with out removing the fuel tank? I get that not alot about these cars make sense, but this seems crazy. Thanks |
Author: | MiniPete [ Wed Jul 14, 2021 9:34 pm ] |
Post subject: | Re: Brake light wiring |
A long spanner and a magnet to catch the nuts should see you through. |
Author: | Harwox [ Wed Jul 14, 2021 9:56 pm ] |
MiniPete wrote: A long spanner and a magnet to catch the nuts should see you through. Is that to remove the nuts on the tail light fittings? Can not see how I will reach the outboard nuts. |
Author: | MiniPete [ Wed Jul 14, 2021 10:02 pm ] |
That's how I do it. Or you can undo the fuel tank strap and tilt the tank over. you don't need to pull it right out of the boot. |
