It is currently Sun Jun 29, 2025 8:39 am
PostPosted: Tue Jul 13, 2021 11:06 pm
Does anybody know the thread size of the valve where it mounts onto the hydro connector?
Mk1 Cooper S
Mini K Rally car
PostPosted: Tue Jul 13, 2021 11:52 pm
External thread on a tyre valve is 0.305 inches (7.7mm) and 32 threads per inch
PostPosted: Wed Jul 14, 2021 11:54 am
Thank you for the info but it is the thread on the other end of the valve that screws into the pipe connector that I am after. Anybody know what it is?
Mk1 Cooper S
Mini K Rally car
PostPosted: Wed Jul 14, 2021 3:21 pm
No sorry I don't.
PostPosted: Wed Jul 14, 2021 3:28 pm
I made a fitting for my hydro pump by soldering a drilled brass valve cap into a BSP brass nipple. It's still working, 30 years later.
I use an O ring inside the cap to seal.
PostPosted: Wed Jul 14, 2021 4:05 pm
Do you mean this thread on the schrader valve to hydro union?
If so, it is 1/8 inch BSPT (tapered). Same thread as the brass drain plug from my mini K original radiator, next to valve in photo.
PostPosted: Wed Jul 14, 2021 11:02 pm
Thank you Bill.That is the thread details I wanted. Thank you to everyone who replied
Mk1 Cooper S
Mini K Rally car
