It is currently Sun Jun 29, 2025 3:20 pm
PostPosted: Sat Sep 04, 2021 10:30 pm
In my parts collection I have two oil coolers with hoses for my 3/70 Mk2 S. They have different sized nut fittings on the hoses : one has 15/16" (from paint colour on cooler, possibly original for car), the other 1". I am going to get the hoses and fittings stripped,cleaned, re-plated (except the brass one) and new hoses fitted. Just wondering which is more correct ? BTW, I'm not using either cooler on the car (they have been sitting un-capped for 37 years), purchased a new one years ago for it.
PostPosted: Sun Sep 05, 2021 9:13 am
PostPosted: Sun Sep 05, 2021 10:50 am
In the second picture, the rhs has the 15/16 fitting and has the car colour overspray on the cooler - probably original. Do I re-use these fittings or the larger 1” ? I know they have different crimps on them and not likely to replicate them exactly.
PostPosted: Sun Sep 05, 2021 12:00 pm
Are the threads the same on both oil coolers?
I don't have my hoses to hand to compare the nuts but the fitting on the oil cooler is 1/2" BSP. The OD of the thread is 15/16".
How are you planning to refurbish the hoses? This will not be a simple job if you are wanting them to look original. The cooler is tested to 170 psi during manufacture so your fittings will need to hold a high pressure.
New aftermarket hoses very close to original in style have recently been remade. You can see them on this page.
https://minisport.com.au/category22_2.htm
PostPosted: Sun Sep 05, 2021 12:18 pm
New repro hoses are available:
https://nippycarsonline.com/product/13h ... -cooper-s/
My 8/'70 oil cooler has the 1" tail nuts on the hose ends. Years ago 1 of the original hoses had a serious blow-out so had new hoses fitted to the original ends. As winabbey said, the ferules or crimps were not the same as original. But the hose and fittings were industrial hydraulic and rated to over 1000psi.
PostPosted: Sun Sep 05, 2021 1:34 pm
Just wondering what the 4 verticle slots are for.
PostPosted: Sun Sep 05, 2021 2:09 pm
The slots are the indentations of the 2 vertical support braces that hold the grill slats. There were meant to be a set of black plastic spacers used to set the grill forward and away from the oil cooler, but mine had lost these before I got it. There are traces of these on ausdino's too.
PostPosted: Sun Sep 05, 2021 2:20 pm
Sign of the grille brace rubbing on mine too.
PostPosted: Sun Sep 05, 2021 5:21 pm
Thanks everyone for replying. All hoses have the same threads. After having another look, only one line has bigger nut fittings on both ends and has different crimps as pointed out by cooperess. This may have been remade at some stage. I have a friend who makes/repairs industrial hydraulic hoses and is confident he can produce something similar to original in form & function. Time will tell. If not, there is the option at minisport etc.
PostPosted: Sun Sep 05, 2021 5:38 pm
I can provide these Smiths labels if you want to replicate original.
viewtopic.php?f=8&t=98478
PostPosted: Sun Sep 05, 2021 8:12 pm
Thanks Doug, I will keep that in mind.
Peter
PostPosted: Mon Sep 06, 2021 7:06 am
I still have some grill spacer's left if interested.
Search Grill Spacer's for more information.
