It is currently Sat Jun 28, 2025 4:29 pm
PostPosted: Sun May 09, 2021 11:04 am
Hi,
I have front and rear hydro competition bump stop kits I'm trying to install and for the life of me, I cannot get the rubber bump stops to fit over the retainer on the bracket. I've scoured the internet and the only advice I find is to use soap and put the bracket in a vise.
After hours of trying various different methods (and now with considerably less skin on my raw hands), I think I must be missing something.
Would appreciate any advice anyone can give me :)
- Merrick
3/71 Morris Mini K
PostPosted: Sun May 09, 2021 11:20 am
I used a dab of raw dishwashing liquid. Put bracket in vice and pushed the rubber down and sideways to get one side in, then turned so it screwed itself on.
I may have pushed a large diameter bar through the rubber a few times to loosen/warm up the rubber as well.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Sun May 09, 2021 12:52 pm
What he said^^
When fitting the rears check the body flange misses the rubber, bend it out a little if needed.
